I have an AOPEN DVRW2412Pro (made by Ricoh actually) and it is a 2.4 X drive. I just purchased 100 printable Ritek DVD+R's and none of them work. They are not recognized by my drive.
I think it is because I need a firmware upgrade but not sure and when I try the firmware upgrade it does not upgrade.
AOPEN uses a RFLASH that works under windows. It has you select the drive and the flash file BUT it does not recognize the drive name UGGG.
Anyone know anything about this ???
problem with playback of 3D on BD -R media
By spot01 in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Sep 2011, 12:46 -
Occuring Media ProbleM
By Joe94 in forum Software PlayingReplies: 2Last Post: 5th Feb 2011, 07:01 -
Media Player 9 Problem
By bevills1 in forum ComputerReplies: 3Last Post: 3rd Aug 2009, 10:52 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
*SOLVED* Media problem or workflow problem? (Media problem)
By nosleep in forum Authoring (DVD)Replies: 7Last Post: 2nd Jan 2008, 20:35
