hey folks...
i was planning on converting the animatrix episodes to svcd to watch it on
my dvd player.
the animatrix episodes come in quicktime 24fps format but converting with tmpgenc to pal takes 25 fps.
how do i convert this ?
i have converted allot of movies (divx/xvid/etc) to vcd or svcd without any
problems because those are delivered in standard pal (25fps) or ntsc (23.976/29.97) format.
i have never converted a 24fps movie to 25fps (pal) format.
could anybody show me how to do this?
Thanx in advance!!
Cheers,
-EsH-
TMPGEnc will adjust the framerate to suit and the video might be a little jerky because of it. 8)
"Art is making something out of nothing and selling it." - Frank Zappa -
i am not sure if it does conversions to mpeg or not, but you might want to try eovideo. It handles quicktime conversions and gives you a 30 day trial. Hopefully this helps?
thanx guys for the replies
ill check the eovideo out...
but what do you mean with '24 to 25 is nominal difference' txpharaoh??
Cheers,
-EsH-
Problem File, cannot convert it.
By sigung in forum MacReplies: 9Last Post: 14th Feb 2008, 12:15 -
Problem trying to convert .flv to .mov
By herdofcaribou in forum ffmpegX general discussionReplies: 7Last Post: 10th Feb 2008, 01:16 -
Mov-convert compression problem
By Blå_Mocka in forum Newbie / General discussionsReplies: 5Last Post: 1st Nov 2007, 08:12 -
Convert Problem
By ewbanks in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2007, 18:38 -
convert x dvd problem
By tofu in forum Video ConversionReplies: 4Last Post: 16th May 2007, 11:13
