Hi
Very new (and very scared) about the whole thing.
I backed up Rodger Dodger using dvd2one. Looks good.
Band of Brothers # 1 was my first multi-episode disc. Of course, Dvd2one wouldn't help with it (without fancy stuff like IFOedit and all that), so I found an easy guide on doom9.
My question: is there a program that will do it all for you? You pop in any kind of movie: multi-episode, widescreen/standard on same side, Goodfellas... any movie and it does it easily and reliably? Such that you aren't stripping VOBs, multiplexing and all the good stuff.
But the movie and the audio should be in P E R F E C T condition.
Is there such an Alladin's lamp?
Thank you everyone.
Results 1 to 9 of 9
Eazy VCD will do it if you are backing up to a vcd - you can get it from the tools menu, not sure about a one program dvd method though !!
No...not planning to back up to VCD.Originally Posted by hardcoreruss
I want as close to possible 1:1 copy of the movie.. point and click, not having to spend time in front of my computer, waiting for step1 to end so that i can start step2.
And this program should be able to handle any kind of DVD.. I shouldn't have to jump from dvd2one to dvdshrink to IC to IFOedit (yes, I am lazy)
Dvd-decrypter to rip copyright protection
pinnacle instant copy to do 1-1 of original dvd
There will be some links on here somewere on how to use it.
john -
Yeah if you want to do that use eazy vcd
not sure exactly where your coming from m8.......
dvd20ne will do it all....latest version does either film only or full disc copying.
instant copy is another option takes longer 3-4 hours as opposed to 30mins with dvd2one.
dvdshrink also does full disc mode and its free???
is it just an issue with band of brothers your having? -
HiOriginally Posted by KYUSS
Thanks for the reply!
I have dvd2one v1.1.1 and I don't remember now but at that time, I wasn't sure i could do BoB with it. Did anyone use dvd2one for BoB?
Thanks. -
no problem m8
its what we are here for after all?
to help each other
so I need to srink with dvd srink or with dvd dycriptor and then do dvd2one or is it all on dvd2one no compression.
black magic shuttle help please
By desiredra in forum Capturing and VCRReplies: 0Last Post: 9th Oct 2011, 21:55 -
Black Magic Capturing
By andy6590 in forum Capturing and VCRReplies: 1Last Post: 4th Jul 2010, 22:44 -
Anyone using Magic Bullet Looks Suite 1.1 to 2.1?
By cooldude859 in forum EditingReplies: 0Last Post: 7th Jan 2010, 03:31 -
Apple's new Magic Mouse
By rallynavvie in forum ComputerReplies: 8Last Post: 20th Oct 2009, 21:51 -
Magic Dvd ripper
By angelus214 in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2008, 13:00
