Hello.. i know everyone has heard this before, but, i am trying to fit a 95 minute movie on one cd in the VCD template with TMPG, or an mpeg1 format. Now i have heard that i should go to the unlock template but, i am unsure of the bitrates for audio and video in order for the best quality, on an 80 min cd-r. Can someone help me please?
Insane_asylum
Use Sefy's SxVCD Templates. You can download them from the left menu section title "Tools". Read the supplied TXT for more info.
i'm just waiting for someone to post a template for TMPGE to produce the best quality 45 min vcd. i figure for most movies it would take 2 cdr's. i'm talking THE best settings for it. i am able to produce next to perfect capture's and i want to be able to squeeze 45 min of it onto 1 cdr with THE best possible encoding.
Just use the bitrate calculator to determine the bitrate, then use ie. TMPGenc's 2pass VBR or CCE's 3-5pass VBR. Resolution should be at least 352x480 (480x480 would be better).
45min woulds be a total bitrate of 2370kbit/s (for audio and video) spilt as you feel best (personally with a good source I just use 128kbit/s for audio). So that would be 2242kbit/s for video. -
i recently got 1 hr 23 mins on a 80 min cd/rw no problems, i used sefys sxvcd template, just reduced the audio rate to 192 k and had no picture degredation (over std vcd) and u cant hear the difference in the audio quality.
<font size=-1>[ This Message was edited by: 85Turbo on 2001-09-17 11:54:00 ]</font>
4 min movie conversion
By Tahir Ramzan in forum Video ConversionReplies: 2Last Post: 3rd Jan 2009, 01:46 -
why a dvd movie's length is longer than 120 min
By hzgg2 in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 19:20 -
makin the movie fit
By xstatictravis in forum DVD RippingReplies: 12Last Post: 11th Apr 2008, 09:52 -
makin a movie fit?
By xstatictravis in forum Authoring (DVD)Replies: 1Last Post: 8th Apr 2008, 21:30 -
5 hour movie on WMP, 90 min movie on MOVAVI
By jchockey in forum DVD RippingReplies: 0Last Post: 24th Aug 2007, 14:14
