  1. Member NES_Master's Avatar
    Dec 2001
    Lexington, NC
    OK, I just got a DVD burner for a while, and I really have to figure out how to use it(Someone's offoring to pay me to make them a load of DVDs) So, I took my video in permiere 6.5 and exported it using the DVD option. I left everything as is except I changed the framerate to 29.97 non-drop frames rather then drop frames. I then authored it(forgot what the prog was called, I'll check on it in a minute, it's on my video comp, not this one) Everything went as smooth as could be expected from a PIII733. Once the DVD finally was done, I tried it on my main DVD player. It looked great and sounded great...just the video was playing twice as fast as suppose to! Ideas?
  2. Banned
    May 2003
    Madison
    You should do it as drop frame instead of non drop frame for starters.
  3. Member NES_Master's Avatar
    Dec 2001
    Lexington, NC
    Drop frame? Eh, ok? I plan to go out an get some DVD-Rs and try again today.
