Has anyone a god setting for Tmpgenc. I'd like to encode some videos to Mpeg1 Pal. It has to be DVD compatible.
If you're encoding for VCD you should use the PAL VCD template. But if your scource (for example) is 29.97 fps (NTSC) you should encode that way (NTSC-VCD, not NTSC/Film) because otherwise your movie will stutter. There shouldn't be any problem for your DVD (standalone) player, it could probably play NTSC video-cd (at least mine can, and I heard that almost all can).
SpruceUp lets u import MPEG1 of correct specification. SpruceUp is a DVD authoring program.
There is a standard - Mpeg1 DVD. It is a ISO 11177????-2. I can't remember. It is a 352x288 Pal. Has anyone info abouth this kind of Mpeg.?
http://www.cselt.it/mpeg/standards/mpeg-1/mpeg-1.htm
MPEG 2 program streams
(ISO/IEC 13818-1)
MPEG 2 video elementary streams
(ISO/IEC 13818-2, Main Profile Main Level)
MPEG 1 system streams
(ISO/IEC 11172-1), including VideoCD (White Book) compatible
MPEG 1 video elementary streams
(ISO/IEC 11172-2)
MPEG 1 audio layer II elementary streams
(ISO/IEC 11172-3)
Guessing here - you wish to encode VHS tape to MPEG1 and play on a DVD standalone !
I use the following TMPEGenc settings and get (IMHO) excellent results (considering the source - VHS tape)
NTSC - [PAL just change 240 -> 288 ]
352 - 240 capture , 352 - 240 mpeg1 @ 2500 video and 128 audio BR.
UNDER :
video tab : MPEG1 , 2 pass VBR @2500 (see if your DVD will read this) and 'highest quality'
advanced tab : i use 'progressive' and VGA1:1 (WHY you ask - well i am plannning for future and just making mostly MPEG1 for now in the hope most TV of the future will just be glorified computer monitors)
GOP tab i use I - 1 , P - 5, B - 2 , seq - 0
output is very good when viewing MPEG1 through my TV out on my video card to my TV. the VCD i have made seem to have a little more 'blockiness' - but not much
more help here
http://www.digital-digest.com/nickyguides/AVItoVCD.htm
<font size=-1>[ This Message was edited by: holistic on 2001-09-16 12:01:13 ]</font>
<font size=-1>[ This Message was edited by: holistic on 2001-09-16 12:01:56 ]</font>
Poor DVD quality: Computer screen recorded to DVD (mpeg1)
By MC123 in forum MacReplies: 6Last Post: 3rd Feb 2008, 16:33 -
question about how to author DVD from several mpeg1 files
By jimdagys in forum Newbie / General discussionsReplies: 11Last Post: 5th Jan 2008, 08:49 -
dvd to mpeg1
By videogirl in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 20:26 -
Mpeg1 to DVD, problems abound - help, please
By Neisse in forum Video ConversionReplies: 6Last Post: 8th Jul 2007, 18:23 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 19:30
