Hi,
Decided to try burning a VCD from my 480x480 source files. I must be missing something because using the VCD template, the aspect ration comes out 1:1 even though I 4:3 is set as default (and can't be changed using the template). Resolution is scaled to 352x240 but the resulting VCD shows 1:1 and square.
If I create my own template and use something like 352x352 as the resolution and 4:3 as the aspect ration, then it comes out 4:3 with narrow black bands top and bottom.
So what's the deal here? I want 352x240 4:3 aspect ratio. How do I achieve that?
BTW, if I change the "source" a.r. to 4:3 then the picture becomes even more squished.
Paul Nixon
16:9 Aspect ratio
By jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 20:44 -
Aspect ratio
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Mar 2010, 12:25 -
what is aspect ratio?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 3Last Post: 29th Sep 2007, 23:29 -
Tmpeg enc Plus 2.5 selects wrong Aspect ratio
By wozmac in forum Video ConversionReplies: 6Last Post: 15th Jul 2007, 18:31 -
Correcting VCD aspect ratio?
By gastrof in forum Video ConversionReplies: 4Last Post: 30th May 2007, 15:43
