tried soundforge, will virtualdub do it? i need it cuz dvdit pe only accepts 48khz for menus
Download DBPoweramp and it's Windows Media Plug-in.
Program-
http://download.com.com/redir?pid=10125657&merid=83769&mfgid=83769<ype=dl_dlnow&lop=...-10125657.html
WMA Plug-ins-
http://www.dbpoweramp.net/codecs/dBpowerAMP-codec-wmav9.exe
http://www.dbpoweramp.net/codecs/db-wmfdist-wma9.exe
(You only need the second one of these if WMP9 is not installed.)
Once you have installed all you have to do is right click on your WMA file in explorer and select "convert to" it's pretty easy from there.
Fozzee -
So many posts get answered and the original person doesn't post back to say if their problem was solved.
rsuave5 please let me know if you tried this.
Cheers
Fozzee
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
Movie's audio out of sync after converting WMA to MP3
By Talayero in forum AudioReplies: 11Last Post: 25th Sep 2009, 04:39 -
Converting .FLV audio to .WAV
By socool135 in forum AudioReplies: 1Last Post: 20th Feb 2008, 19:24 -
Best App for Converting MPEG2 files to WMV/WMA 5.1
By JBredensteiner in forum Video ConversionReplies: 13Last Post: 7th Oct 2007, 14:58 -
Converting mp3 to wma with Vegas 6.0
By solarblast in forum AudioReplies: 2Last Post: 1st Oct 2007, 06:50
