Almost every movie that I try to convert from Xvid to Mpeg using TMPGE crashes. IS there a "special" way to convert Xvid that is any different than when converting divx?
Thanks in advance
Results 1 to 10 of 10
Hey,
I'm also having troubles converting xvid to mpeg2.. the coding will run for about 24 hours and it will tell for 16 hours it still needs 6 more hours.. so it will keep running but not doing anything.. I checked the avi with virtualdub for bad frames and it said there wheren't any.. i run the file with gspot to see if i got all the codec there and i had.. What am i doing wrong..
Yf -
hi,
i have also trouble with xvid to mpeg2, it will not play on a standalone,
use virtualdub and tmpgenc, whitout success. -
What are your methods for converting ?
When you say it crashes, how ?, what error message ?, in what program ?, are you frameserving ?, using tmpgenc ?, did you extract the audio ?
More information please !!!
what do i use:
tmpgenc 2.510.49.57 Pro
tmpgenc 2.511 evaluation
settings:
http://dvd-hq.info/Calculator.htm is the site i use to determen the settings i need but basic it will be a two pass encoding without the audio.
codec:
XviD-04102002-1 _ALPHA_ Release
i hope this helps.. When i get the coding to mpeg2 do the dvd will play fine but most of the xvid will not encoded for me with tmpgenc.. after running 24 hours i still got no m2v file and the counter of tmpgenc is still telling me there is 6 hours encoding left.. but thats is what is started with.. -
http://www.roeder.goe.net/cgi-bin/fetch?file=XviD-04102002-1.exe
Latest Stable binary. -
ok personally i think XVID movies are easier to convert than DIV3. ok all you do is open a program called AviC(four CC changer) and you open up your XVID.AVI and then you change it to DIVX on both boxes and then you put quit. this takes about 1 second. now you can try that and put it in Tmpeg or CCE and you shouldnt have a problem, but if in case you do use GoldWav to extract the audio and combine the video and audio using VDUB. and then you shoulnt have any problems with syncness or anythign
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
Wow.. it cant be that easyOriginally Posted by Cecilio
it wasn't ..lol.. when testing a playback before converting, all I get is a blank black screen.
mp4 xvid vs H264 mpeg-4 avc quality difference
By johnharlin in forum Video ConversionReplies: 2Last Post: 8th Apr 2012, 08:38 -
Best possible quality XviD to DVD
By Mdoodm1000 in forum Authoring (DVD)Replies: 7Last Post: 9th Dec 2010, 10:01 -
how many avi/xvid to dvd before quality loss?
By wingfan in forum Video ConversionReplies: 10Last Post: 14th Jan 2009, 15:38 -
Highest Quality XVID to DVD
By Merkaba188 in forum Video ConversionReplies: 10Last Post: 1st Jan 2009, 22:58 -
How to get the Highest Quality from DVD -> xVid or whatever is better?
By mistafro in forum ffmpegX general discussionReplies: 10Last Post: 22nd Aug 2007, 14:25
