  1. I have been trying to get a DVD-R/W or DVD+R/W disc to play in this player and it will NOT read any of the four formats! I have tried a Verbatim DVD+R, Sony DVD+RW, Maxell DVD-RW, and Memorex DVD-R and none will work with the RP91! The DVD+R/W discs work on my Sony DVD-ROM but not the Toshiba DVD-ROM, The DVD-R/W will work on both DVD-ROM's. I used DVD XCopy as well as DVD XCopy (copying the files before the burn takes place) and then use Nero to burn the files (under DVD Video) with no luck!
    Does anyone have the RP91 and what are you doing to get DVD's tp play in the player?
    My Computer Setup:
    Pentium 4 2.67GHz.
    512MB Rambus 1060
    Two 80GB 7200 RPM Hard Drive
    GeForce 4 Ti4600 w/128MB
    ASUS P4T533-C Motherboard
    Sony DRU500A DVD-R/W, DVD+R/W Drive
    Plextor 40/12/40a CD-RW Drive
    Sony DDU1621 DVD-ROM Drive
    Toshiba SD-M1612 DVD-ROM Drive
    Thanks in advance for your help!
