ok, i readwhat was posted, but could not find why a VCD with only regular pal 352-288 at 1150 kb/s and audio 44000 - but with chapers - end up with colored squares, then audio bursting peeks, then finally crashin the player.
tried 48000 but of course the result is terrible...
I create the mpeg with TMPGEnc using VCD Pal template, then the bin/cue with vcd easy, final burn it with nero. I even trie ulead DVD MovieFactory 2... even worse.
There are so many things which could be wrong, like burning speed, ISO, chapters... but i'mtired of spoiling cd...
any idea greatly appreciated, cause i'm stuck!
Consider Phlebas, who once was tall and handsome like you.
The first thing you need to test is whether or not your player can read your particular brand of CD-R media well.
Burn an audio CD on the same media and see how well it plays.
Regards.Michael Tam
w: Morsels of Evidence -
Thx Michael..
I don't have any more of these media... for obvious reasons; the brand was 700 MB CD-R from imation.
I bought some CD-RW650 from TDK and will do what you suggested first.
You mean copying (with NERO) an audio CD? or making a fresh new one?
thank you for your help.Consider Phlebas, who once was tall and handsome like you. -
Um... either way...
Just make an audio CD onto the CD-R/W media you want to test (copy an existing audio CD or make your own compilation if you want to).
Regards.Michael Tam
LG DVX 350
By mattin in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Sep 2010, 10:46 -
A Better Way To Run a PVR-350?
By hech54 in forum Capturing and VCRReplies: 0Last Post: 29th Jun 2009, 23:56 -
PVR-350 Problems
By nealf in forum Capturing and VCRReplies: 23Last Post: 26th Nov 2008, 22:47 -
Pioneer dv-400v XVID playback problems
By ironzenmountain in forum DVD & Blu-ray PlayersReplies: 15Last Post: 3rd Sep 2008, 23:22 -
Pioneer DVR 630 HS - Recording will not playback
By ktmsprocket in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th May 2008, 12:06
