Following on from a previous post, I am trying to eradicate audio sync problems when creating a VCD DVD. I am using VCD quality encodes of Smallville. I have used SVCD2DVDMPG to create *mpa and *.mpv's of the first 10 episodes.
I am now using the guide on the SVCD2DVDMPG website as a template to create my own DVD. I believe that I have done it ok but now I have a problem...
When I hit compile everything goes ok for a bit. Then after it has compiled VTS#7 I get the following error message poping up in a box...
Sequence Header Duplication Error
10 Warnings :
- Movie Episode 1 : At least 1 Audio Track must be PCM or AC-3 Format
It says this 10 times once for each movie. (I have set DVDMaestro up with 10 seperate movies - each movie being a different episode)
If I look in the output folder I have 2 VOB's for each of the first seven episodes but only 1 VOB for the final three (each of which is only 114Kb) the first seven episodes play fine (no audio sync problems - YEAH) in PowerDVD but the final three won't play (obviously cos they have not been coded) and their are no *.IFO's
Anybody any ideas??
Ok this (for me anyway) just got really weird....
I deleted the first seven movies out of the DVD Project leaving only the menus and episodes 8, 9 and 10 remaining. I pushed compile and it did it properly. I still got the same audio warnings, but the files played fine in PowerDVD so it's not the *.mpv or *.mpa's fault.
Now I am competely all at sea!!! Someone Help please!
Results 1 to 1 of 1
How to write randomizer script in DVDMaestro
By GomezOptions in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2011, 00:15 -
DVDMAESTRO sx32w2.dll
By twinegar in forum Authoring (DVD)Replies: 1Last Post: 16th Mar 2010, 12:04 -
Wrong frame rate (30 fps) for DvdMaestro. Any solutions?
By conax in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2009, 17:36 -
How to add multiple audio tracks in DVDMaestro?
By rbatty11 in forum Authoring (DVD)Replies: 0Last Post: 5th Sep 2007, 07:48
