I find the solution myself, thanx to another post. It seemed that if I used the frame rate as the DIVx file was made in and made an NTSC VCD instead of a PAL VCD everything worked out fine, a little loss of quality though, as my TV cannot display NTSC.
I use TMPGEnc 12a and everything works good, when I convert a DIVx file to a VCD. But all Divx files encoded with low motion, makes the final VCD to pause, just for a millisecond, every 5 or 10 seconds. Quite disturbing...
Divx with fast motion is no problem at all.
I have tried everything, I think, but the problem is still there. Could it be my computer that is to lame(766Mzh Celeron, 128MB RAM)
Would be great if anyone could answer this one, before I go crazy...
<font size=-1>[ This Message was edited by: KenneB on 2001-09-16 13:15:32 ]</font>
Results 1 to 1 of 1
A strange Windows 7 error
By netmask56 in forum Newbie / General discussionsReplies: 4Last Post: 8th Apr 2012, 09:21 -
Strange things happens in my VCD menu
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 0Last Post: 28th Nov 2010, 03:07 -
Getting a strange error in iuVCR now out of nowhere .. !
By ahmadka in forum Capturing and VCRReplies: 1Last Post: 23rd Jul 2010, 08:51 -
Strange error in captured video
By Makinus in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2008, 18:16 -
A very strange error in mediaserver
By d2idan in forum Media Center PC / MediaCentersReplies: 4Last Post: 16th Jun 2008, 20:48
