i cant seem to get this working properly. i get the followin error
any ideas?Code:Reading /Users/1stunna/.mplayer/codecs.conf: 50 audio & 136 video codecs File not found: 'frameno.avi' Reading config file /Users/1stunna/.mplayer/mencoder parse error at line 1 sh: line 1: 1114 Bus error /usr/bin/mencoder / Volumes/Plop/Tosort/BARRY_LYNDON/TITLE01-ANGLE1.VOB -oac mp3lame -lameopts cbr:br=128:vol=0 -aid 128 -ovc xvid -sws 2 -xvidencopts bitrate=1213:max_key_interval=240:4mv -ofps 23.976 -vop scale=640:352,cropdetect -ss 1:00 -endpos 0:05 -v -o /Volumes/ Plop/Tosort/BARRY_LYNDON/lol3.avi
someone from another forum told me that it looked like i was using a new version of mencoder, and that it wouldnt work with the current ffmpeg. i really dont know if this is true, but if it is, where can i find older versions of mencoder. or if anyone has this working, could they explain whats going wrong?
Use the mencoder binary located inside this application package (ctrl-click the Mencoder application icon, select 'Open application package' then find the binary inside the Contents/Resources folder).
thanks major, and i think im getting much closer, but now i get this:
?Code:Reading /Users/1stunna/.mplayer/codecs.conf: 50 audio & 136 video codecs File not found: 'frameno.avi' Reading config file /Users/1stunna/.mplayer/mencoder parse error parse error option without parameter option without parameter parse error parse error parse error option without parameter parse error option without parameter parse error option without parameter option without parameter parse error option without parameter option without parameter too many errors Exiting... (configfile error)
ffmpeg encoding to xvid + ac3 5.1 -- can't make it work!
By suroit in forum Video ConversionReplies: 2Last Post: 4th Jan 2012, 17:13 -
need hq xvid ffmpeg preset for kdenlive, with deinterlacing
By codemaster in forum LinuxReplies: 0Last Post: 3rd Jul 2011, 01:56 -
Which ffmpeg build plays xvid in virtualdub after encode? ... [RESOLVED]
By vhelp in forum Software PlayingReplies: 1Last Post: 4th Sep 2009, 23:04 -
FFMPEG AVI (XVID) to IPOD Mp4, AUDIO OUTPUT is 2x Normal Speed, HELP!
By jiulonghks in forum ffmpegX general discussionReplies: 1Last Post: 21st Sep 2008, 00:35 -
Getting FFmpeg to use XviD codec with 4:3 instead of 1:1 pixel output?
By PBear in forum Video ConversionReplies: 7Last Post: 10th Jul 2008, 16:03
