  1. Hi
    I have a Disk with both version on it.. Widescreen version and all extra would fit on a DVD-R.
    Question:
    If I open the Full screen vob with IFOedit, then keep only the 00.18 (sec) black flash vob ID, does it will work ?
    I have done this with extra for Stigmata, but want to know if it would work with a Full screen movie (keeping the wide version) ?
    Also, what are the files in the JACKET_P folder ? are they needed ?
    thanks
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    JACKET_P and files are not required - its a extra thing mostly for sony dvd players and is optional
    see the glossary
  3. open all the ifo's & find the one refering to the 4.3 version & just delete the vobs linked to that ifo as thats what I done with legally blonde & it worked nicely, done the same with enough & so fare had no bother. I also used menu edit to bar the access to the 4.3 version aswell though
