  1. Hello all.
    Here's what I'm trying to do:
    1. Rip The Wizard of Oz. (I mananged to do this with SmartRipper)
    2. Add Dark Side of the Moon as secondary audio track to the film.
    3. Burn it to a DVD.
    I want to do this all without re-encoding, because there should be enough room for this on a DVD. Anyway, I'm stuck at the second step. I've ripped the CD to .wav, but I haven't figured out how to convert it to a DVD format or how to add it in as another audio track. I'm very new at DVD, because I just got a burner. Any help anyone can give me will be much appreciated.
    Unno
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    check the specs on your authoring program - many consumer-level dvd-authoring apps do not support authoring of multiple audio streams.
    Sonic ReelDVD does, Maestro does, hopefully DVD Lab will have this feature added...
    - housepig
  3. Well, isn't that stupid. I'm using TMPGEnc's authoring program. I could buy another authoring program if need be. Could you suggest which one you think is the best.
    Thanks,
    Unno
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    "best" depends on what you want to do....
    if multiple audio tracks is a deal-breaker, I would suggest looking at Sonic ReelDVD. I did a search at one time, and it seemed that was the most affordable option ($699 msrp).
    without that consideration, I'm liking DVD Lab quite a bit right now - it's in beta testing stage, but it should be released in a month or two. If you do a forum search for DVD Lab you should find a link to download and try it.
    - housepig
