Results 1 to 11 of 11
  1. Member rhegedus's Avatar
    on the jazz
    Sorry, I'm a muppet!
    I've changed the default DVD+-(RW) size for the full copy to destination and can't remember what it should be. Was it 4700Mb - anyone able to help?
    Regards,
    Rob
  2. 4300 or less, 4420 orig i think
  3. 4300 or less, so you dont write on outer
    edge of disc....
  4. 4460 is the default and the program really needs a "reset default" button IMO.
  5. Do a regedit do a find on DSTSIZE delete the entry 'DVD±R(W)' then next time you start DVD2one you will have the default size.
  6. Uninstall - Re install if it means that much to ye
  7. oddly my default is 4472 and works fine.
  8. You can probably get away with 4482 and be fine. Fill that disc!
  9. Member rhegedus's Avatar
    on the jazz
    Thanks all.
    Regards,
    Rob
  10. Member rhegedus's Avatar
    on the jazz
    I've been playing around with DVD2ONE and Nero all morning and 4450 seems to be just right. Strange, I thought it was higher....
    p.s. This all started when I tried to back up Die Another Day disk 2. The default DVD2ONE setting (which was right up to the max with Nero) was too bigh for Nero. Weird
    Regards,
    Rob
    Regards,
    Rob
  11. i always use 4400 mb setting myself,i think the default for dvd2one is 4472mb.as long as the quality of the blank dvd is good 4400 is fine i think,if it is an average quality blank i would go for 4000.
