I am having problems with the speed of my ripping with smartripper it only rips at .2X and i have a 16x dvd player on a p4 1.4 ghz system anyone know how to get this to speed up? dma is checked on drive.took 4 hours to rip coyote ugly but only 10 min to rip george of the jungle what could cause such a diff?
<font size=-1>[ This Message was edited by: wjeremy100 on 2001-09-17 19:36:02 ]</font>
<font size=-1>[ This Message was edited by: wjeremy100 on 2001-09-17 20:37:53 ]</font>
I'm feelin' your pain, too. My system specs are like yours, but, I can't get any faster than 1.2x.
go into explorer and right click on the dvd drive and chek if the dma option is checked?
Well something is definitely wrong. On my Hitachi 8x drive, I usually rip between 3-5x and it can peak at >7x.
Make sure DMA is turned on for your drive as this can make a big difference.
Someone quite a while ago mentioned that (paradoxically) turning off UDMA support for the drive in BIOS actually speeded it up. You could try this -- it's harmless and you can always change it back.
Regards.
Michael Tam
w: Morsels of Evidence -
how do you turn on DMA? someone said something about explore... but can't find the option...please help
wow... I'm stock that no one really knows the answer to the questions...
Thanx for the advise, but didn't solve to problem yet!!!
Where's the guy with the brains on the site? need his/her HELP!!! alot of us can't get it past 2X...
my old machine went to 5X -
Well, I checked the DMA box in my DVD properties box (accessed through the Device manager, Systems, CDroms) and have rebooted it, but I'll have to clear some room on the drive before I can try it out. Windows claimed that turning the option on could have "undesireable effects on the Hardware" whay would it? What is this DMA thing?
Any chance your drive is a Toshiba? Mine is and I have noticed that it does dvd's at different speeds. I read on some other posts though that something is built into the Toshibas that limits their ripping speed to 2x on certain encrypted dvds.
Daemon Tools can slow rip speed
By ocgw in forum Blu-ray RippingReplies: 8Last Post: 11th Nov 2013, 11:07 -
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Using dd to rip a dvd movie to an iso file - seriously slow
By graysky in forum LinuxReplies: 1Last Post: 10th Apr 2009, 14:36 -
rip w FAB then reauthor w SHRINK --> very slow to start playing
By JohnnyBob in forum DVD RippingReplies: 6Last Post: 13th Jan 2009, 09:41 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
