  1. Can someone tell me how to extract the .mpg file from an SVCD so that I can run an MPEG fix over it... I lost the original M2V file and now the .mpg file cannot be copied off the disc I burnt (it is not a valid file)
    Any help would be greatly appreciated!
  2. If you make an image of the SVCD using CDRWin and then take the BIN/CUE file into VCDGear it will make an mpg from this SVCD. I've done this with Familyman which was posted as SVCD but in BIN/CUE format and it worked for me.
    Hope this helps.
