Is it possible to use DVD disc to make VCD. If possible, that means I can have up to 4 to 5 hours of videos in the DVD disc using VCD format. Can the regular DVD player able to play this or it would confuse the player.
Check here: https://www.videohelp.com/vcddvdr.htm
8)"Art is making something out of nothing and selling it." - Frank Zappa -
Your looking at it wrong I think.
Can you make a DVD with Bitrates and resolution comparable to VCD?
Yes or very close
and you can get 4-6 hours on a DVD this way.
Maybe CVD with 352x480 @ 2000 bit rate to start, but I warn you the results may be better than VCD. Trail and error to find a fit for your needs.
Author VCD files in a to DVD Disc
By akakiami in forum Authoring (DVD)Replies: 6Last Post: 5th Jan 2009, 05:22 -
Help:How to author 3 disc vcd movie into single dvd without reencoding
By devstallion in forum Authoring (DVD)Replies: 6Last Post: 31st Dec 2007, 03:40 -
Copying, Copied DVD-RW DISC TO DVD-R DISC
By 306james in forum FeedbackReplies: 2Last Post: 12th Nov 2007, 04:44 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 12:50 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 19:55
