i've just downloaded a couple of songs from a concert from which i'm trying to make a vcd.
when i'm joining a couple of mpeg-1 videos I get a slight pause between parts... how can i avoid this? if it's possible?
when i'm playing the vcd on my dvd-player the video doesn't cover the whole tv-screen, it's in the upper left corner. the mpeg is in the size 320x240 (ntsc).. how do i change it so it fills the tv-screen?
Try NTSC 352x240 which is the VCD resolution. Note that the QT Player doesn't correctly report MPEG resolutions so use apps like MPEG Info X instead.
this is the info i get with MPEG info X:
Mpeg 1 System File [Video/Audio]
Muxrate: 1.41 Mbps
Estimated Duration: 03:19.70s
Aspect ratio 1/1 (VGA)
Size [320 x 240] 25.00 fps 1.15 Mbps
Audio: Mpeg 1 layer 2
192 kbps 44100 Hz
Stereo, No emphasis
so.. what software do i use to change the size? -
I'm not 100% if this works but try to make the following pipe in MediaPipe:
File Browser [choose the demultiplexed input file]
File Streamer
MPEG Decoder
Color Conversion
Add Borders: Top: 0, Bottom: 0, Left: 16, Right: 16
MPEG Encoder:
ppmtoy4m: -v 0 -S 420_jpeg -I p -F 30000:1001
mpeg2enc: -v 0 -f 1 -F 4 -n n -a 2 -b 1152 -I 0 -r 16
multiAVCHD prevent pause between tracks
By yoboha in forum Authoring (Blu-ray)Replies: 1Last Post: 28th Sep 2010, 09:17 -
bizarre bug - DVD tracks playing in wrong order in DVP5990/92
By lhughes in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Aug 2010, 05:23 -
newbie question, vhs tracks
By alcez in forum AudioReplies: 8Last Post: 16th Oct 2009, 12:41 -
mini-dvd with tracks recorded wrong
By gadboa in forum Video ConversionReplies: 5Last Post: 17th Jul 2009, 11:51 -
Wrong Size at Spliting
By Flowbax in forum EditingReplies: 3Last Post: 16th Jul 2007, 14:33
