Are there any tool do a quick conversion to convert pal to ntsc, some of the file i got is PAL system,
I use DVD2One to convert a movie but find out it is a PAL dvd. is there any way i can convert the finished DVD5 VIDEO_TS content to NTSC?
thanks
Not sure about vobs, but canopus pro coder does a great job with pal to ntsc.
Try this trick. I have successfully ripped and converted sereval UK issued DVDs to play on many different US only/ non firmware upgradable DVD players. after ripping the contents to the HD using Smartripper 2.41, i used IfoEdit .95 to remove the region code restriction and replaced the PAL header with NTSC headers. Them Burn them onto a 4.7gb DVD+R. So far have not ran across a DVD player that will not play them.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
