Hi all
I recently bought the card in the title. Had lots of problems getting it installed on Win XP (Stop errors, etc.), but finally got it working with updated drivers from the Leadtek site. Then I read that I might get better quality captures if I used the tweaked BT848 drivers, so I tried them out. Picture quality was improved, but I couldn't capture audio or use the cards FM radio tuner. After messing around for a while, I decided to re-install the Leadtek drivers, but now Windows isn't able to see them. I'm directing the hardware install wizard to the unzipped folder with the driver files in them, but no luck. Can't even install the original drivers from the CD. Does anyone know of a way to fix this???
Thanx in advance
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 11:32 -
leadtek PxDVR3200 H - HD component input
By Thalandor in forum Capturing and VCRReplies: 1Last Post: 30th Oct 2008, 20:10 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 09:05 -
What is better than a leadtek expert tv tuner card?
By Gplracer in forum Capturing and VCRReplies: 1Last Post: 7th Jul 2007, 13:44 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
