OK,
So I bought the ADVC-100 and I have XP, SP1. I've connected S-vid, audio (L/R) into the 100 and firewire to my Sony Vaio (6-pin on vaio, 4pin on ADVC).
So - fire up scenalyzer and I have vid, but no audio. I've done a bunch of searching here and while I see folks with lots of problems like this - I have yet to find the answer...
So - sorry if this is something that's been asked and answered but I can't find it...
So - if anyone can point me towards the answer, much appreciated.
Thanks in advance.
- Kevin
Kevin,
I have an ADVC-100 and also had problems like this when starting out. Your problem most likely is due to the fact that most applications use VFW and XP uses WDM for video capture across firewire.
I have seen this with several applications including VirtualDub
Snag a copy of DVIO and see if your problem goes away. I believe there is a link to it in the tools sections of this forum.
You might also think about downloading one of the Ulead trial programs and giving them a try.
Good luck,
Dave
----edit----
I am not very familiar with Scenalizer, if it uses WDM, it might be a DV type 1 vs type 2 issue.Just what is this reality thing anyway?
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15 -
At wits end - Capturing with ADVC-100 and audio levels are extremely low
By Towncrier in forum Capturing and VCRReplies: 13Last Post: 18th Sep 2007, 19:04
