I get very frustrated using TMPGEnc (2.5 Plus).. I can never figure out what the problem is.. It may be me that's the problem but i swear -- one minute it accepts avi files and rejects it the next ('unsupported'). it's like the damned thing is 'alive' and is just plain f'g w/you and laughing its arse off while doing so..
Can someone PLEEEASE explain how to work or manipulate TMPG in order to get it working properly/consistently??
For example, i was trying to demux an avi file and it kept rejecting the file ('invalid mpeg format' or something like that..). I could have sworn i've done this before successfully several times.. Other times, i've tried importing mpg/2 files to re-encode and i get an 'unsupported' error.. I've tried re-prioritizing in the 'environmental' setting to no avail...
Again, it might be the 'user' (me..but i see many posts addressing tmpg problems. Thanks!
Hi jbenj01,
First, You can't de-multiplex a .AVI file using TMPGEnc, that's as far as I know. You can use vdub and frame serve to TMPGEnc, create a .M2V file and Multiplex audio and video.
Second, You can re-encode MPG-1 not MPG-2. I don't know the reason for this
, but to re-encode MPG-2 you have to de-multiplex and use the .M2V file with other tools to frame server to your encoder......e.j. DVD2AVI--->VFAPI ----> TMPGEnc, AVISYNTH ----> TMPGEnc.
Some Day I will….. -
Sorry for the first part, it is not truth.
You can encode .AVI direct in to TMPGEnc, but if you want to separete audio and video you have to use a tool like VDUB
Some Day I will…..
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
