How can I convert a smaller mpeg1 such as this (160x112) to a VCD stream (320x240) without enlarging or "blowing up" the image.
I basically want to retain the 160x112 size in the middle of the screen and create a black box around it to reach the 320x240 size is this possible???
If you want to do this for any odd reason, select at the TMPG advanced tab video arrange method "center(costom size)"
160x112 pixels. Load a VCD template or set resolution at the video tab to 352x240. -
Am I wrong, or would the conversion to vcd make the resulting image "soft" or less quality than the original seeing the original is smaller. If not, then there is no reason for me to try and create this border. Does the vcd encoding take this into account and interpolate it in some sort?
How do I calculate bitrate for 320x240 .m4v?
By dave692 in forum DVD RippingReplies: 1Last Post: 5th Aug 2011, 17:31 -
Why is there no such thing as 60FPS above 320x240?
By Syclone0044 in forum Newbie / General discussionsReplies: 29Last Post: 28th Sep 2009, 15:22 -
3GP with 320x240 not possible?
By ahollmann in forum ffmpegX general discussionReplies: 2Last Post: 22nd Aug 2009, 06:29 -
320x240 mp4
By OG24 in forum Newbie / General discussionsReplies: 15Last Post: 17th Jul 2008, 03:14 -
Issues converting to 320x240 AVI
By 009 in forum Video ConversionReplies: 5Last Post: 14th Jul 2008, 03:23
