  1. I am giving this a try. What the app never starts in the log window I get an error
    "The chosen drive does not support files >4GB, I am running Windows XP.
    What Do I need to do?
    "Seek you will find it"
  2. you need to be running NTFS filing system as FAT 32 does not support files above 4 GB
  3. How do you do that?
    Thank you.
  4. By converting your FAT32 to NTFS.
    I think you can find this utility in the system tools.
  5. In the command prompt window, type
    convert drive_letter: /fs:NTFS
  6. Thanks for that, I just bought Parition Magic, it does it all!
