Hi
I have some dvix/xvid movies that I'm trying to put on SVCD. I know how to use VDub to rip the audio to a wav and then use TMPGEnc to rip the video but.....
if my divx/xvid movies are 5 channel audio, VDUb doesn't seem to want to play ball. I've tried defining that I want a two channel, 44k audio file, but when I try and save to wav it gives me an error message and refuses.
Do I need to rip the 5 channel to 2 channel using something else first?
W
In vdub, select audio->direct stream copy.
Then file-Save wav.
Change the name of the save file to file.ac3. Then use HeadAc3he to convert this to whatever format you want (Stereo, wav, mp2, mp3).
If HeadAc3he gives an error, try running the .1c3 file from vdub through ac3fix.exe
All these tools are available in this sites tools section. -
detailed guide
https://www.videohelp.com/sefy/?id=wavextract2.html -
wow that was quick!
This site and forum never cease to impress me.
Thanks very much indeed.
w -
You might even be able to do it using GoldWave.
Just open the AVI, and save it as a WAV - I saw someone mention that once and keep meaning to try it. -
Any time that I have AC3 audio or VBR-MP3, I always use Goldwave to create my wav file.Originally Posted by Mr Grumpy
Delaycut question about 6 chan ac3 out of sync when 2 chan is in sync
By B2K24 in forum AudioReplies: 3Last Post: 27th Apr 2009, 17:10 -
Resize Divx/Xvid For Portable With VDub: Artifacts/blur
By gordonliu in forum Video ConversionReplies: 6Last Post: 4th Apr 2009, 09:42 -
vdub and audio
By jimbb in forum AudioReplies: 1Last Post: 9th Apr 2008, 11:17 -
VDub/Divx - How to setup Aspect Ratio
By neomaine in forum Video ConversionReplies: 7Last Post: 6th Feb 2008, 17:05 -
can't compress audio in vdub
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 06:26
