I have lots of old HI8 tapes and my cam no longer works, i have been looking for a VCR or converter to play the tapes on but not having much luck. Anyone help me??
Thanks in advance for everyones help.
Good Luck!
One option might be a D8 cam, which will play back Hi8 tapes, and do it better than a Hi8 machine would due to its digital noise reduction circuit. Ideally, I'd make a project of transferring tem to DVD or some other medium, since the cam isn't going to be great as a heavy use playback machine.
I found a couple of used TRV120 cams on eBay for around $350 - that's another option.
Should I capture VCR, 8mm and Hi8 tapes to MPEG2 or MPEG4?
By dorenhagen in forum Capturing and VCRReplies: 18Last Post: 25th Jan 2011, 23:00 -
Hi8 VCR help
By Famicoman in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 19:32 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 23:06 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 02:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 07:26
