i need help with video to video transitions from one to another that are already in mpeg format.Or if there is a easy way to do it in avi with software.Thanks
You are not very clear in what you want. Do you simply want to make a duplicate copy of an existing mpg ?
Sorry about that i want to know how to have a smooth transition from one clipe to the next.Like putting pics at the start a endding of a music video.Some i have already made mpegs others are avi.I need to get rid of the sudden ending on my videos.I relly don't understand Premiere to well. once again sorry
Not hard to believe that you don't understand premiere, that program is a lot harder than it needs to be. I'd suggest you check out Sonic Foundry's Video Factory if you're looking for something that is cheap, powerful, and easy to use. http://www.sonicfoundry.com/Products/showproduct.asp?PID=490
How can I convert a walmart security video .avi(sn40 codex) to normal video
By DrBaheim in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2025, 19:58 -
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
Problem: Video Black and White in Samsung MM-DG25, How to change video outp
By GetmeColors in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jan 2011, 12:11 -
Freeware App To Change Video File Size, But Not Video Or Audio Codecs
By LouieChuckyMerry in forum Video ConversionReplies: 4Last Post: 19th Jun 2010, 10:06 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 10:05
