I have the DVD Workshop version-1, and I am trying to upgrade to the 1.3 version. However, when I run the upgrade program, I get an error to the effect "Ulean DVD Workshop not found on this computer". Why do I get this error? what is the upgrade looking for and unable to find? I dont want to have to pay full price for another version, just to get an upgrade to something I already paid for...
I have seen this when someone has tried applying to a Trial version.
I have also heard of this happening when someone has tried applying to a cracked version.
Seeing you have a legitimate original, I suggest contacting Ulead for support if no-one here has a better suggestion as you should not have to buy another copy.The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
Ulead will assist you with this if you make certain you have registered your Ulead product.
If you have registered, then go to this Web page and log in:
http://www.ulead.com/tech/Suppform.htm
Once you log in, you'll be able to fill out the official tech support form and get a resolution to the problem.
Jerry Jones
http://www.jonesgroup.net
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 23:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55
