Just need some help with capturing
What is the best codec i should use to capture if i am planning to capture tv eps -> cut out the ads -> and then encode to vcd
Thanks anyone
1. Capture straight to MPEG. Realtime encode.
2. Then use TMPGenc's MPEG Tools to cut the good parts out into new temp files and rejoin the temp files to a final joined file (effectively removing commercials). Takes 5 minutes at most.
3. Finished. No more steps. Burn your disc.
** I'm sure somebody will come along and try to make you capture AVI, edit in Premiere or VD or something, speak of Huffy this and that, lossless this and that, etc... But in the end... and HOURS later their way... you'll have the same thing I mentioned above. Now if you cannot capture MPEG, you'll pretty much have to do it their harder/longer way. **I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Hey . . .
txpharoah - what application do you suggest supreme_commander use for for realtime mpeg capturing? *curious* I've used PowerVCR II a couple of times (profile = DV "excellent quality", video smooting and intelligent noise removal both turned on) but haven't been all that impressed with the quality as opposed to an avi that's been filtered and encoded.
B.===============================
"Don't ask for my specs - click the b*&^dy button . . ."
Txpharoah,
I too am interested in what you use to capture and encode in real time without getting motion or audio synch problems. You have described the alternate method to a T that took me months to figure out and get working to my satisfaction. I would love to "step up" to real time at an affordabe price. I assume that there is no double encoding by Tempgenc?
Richard
Which codec is the best for capturing VHS?
By aaxpers in forum Capturing and VCRReplies: 2Last Post: 27th Jun 2011, 06:45 -
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 21:54 -
Use a software codec when capturing with an ADVC300?
By timothyd_1975 in forum Capturing and VCRReplies: 22Last Post: 15th Jun 2009, 23:06 -
Best compression codec to use when capturing 720p video?
By Mysteriouskk in forum Capturing and VCRReplies: 3Last Post: 24th Nov 2007, 23:51 -
Which Codec is the Best for Capturing?
By rocknico100 in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 20:47
