My system:
Asus K7V AMD 1GHz, 256MB RAM, 40GB HDD, 5400U/min, ATA100
When I use the reference Drivers from Nvidia (V21.81 or older), the capturedriver from Asus isn't working. Even worse the live-Video seems to been displayed in PAL Resolution (704*575), but at a frame-rate of 30fps. This result in a flickering display of the picture.
Do somebody know a resolution for this problem?
Thanxx in advance, Erik
Just a thought
Have you tried the new beta driver from asus for your card - last one I got was ver 12.91 - works better with some codecs than others and differently to the driver supplied with the card (ver 6.31).
Do you not need this driver to run with the asus capture driver - once this is installed you can then open the digital vcr application and change the capture properties there - then open virtual dub (or whatever) to do the actual capturing.
scattergun
PAL - what is its resolution in 16:9 broadcasts?
By snadge in forum DVB / IPTVReplies: 19Last Post: 22nd Oct 2013, 07:01 -
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
how to convert ntsc to pal without changin the resolution?
By Remyisme in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2009, 18:30 -
Anamorphic PAL 4:3 (576i) - least lossy resolution for web publication?
By Bubblevision in forum Video ConversionReplies: 1Last Post: 8th Feb 2009, 08:25 -
PAL is bigger resolution than NTSC....?
By snadge in forum Newbie / General discussionsReplies: 17Last Post: 19th Jan 2008, 13:18
