I have just gotten a new DVD Writer, the LG GMA4020B.
I have several movies that are in SVCD format right now, and just saved as data files on CDR. What I would like to do is put them on DVD, 2 movies per DVD.
My question is:
Since the movies are all in two parts, is it possible to put the four files onto a DVD and setup the menu so you select #1 or #3? But have #1 play file #1 and file #2. Have #3 play file #3 and file #4. If you know what I mean.
Will -
LHS menu: How TO : Guides : Format Conversion: SVCD to DVD:
https://www.videohelp.com/guides?formatconversionselect=SVCD+to+DVD
However I'd use svcd2dvdmpg or even svcd2dvdmpg+ when its out in a few days....SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Let me rephrase the question.
I have four files totaling about 3.2GB, they are 480x480 @29.997 FPS and the audio is 48KHz.
The four files are DVD ready, my DVD stand alone is a Pioneer that plays VCD and SVCD.
Movie_01_A.mpg
Movie_01_B.mpg
Movie_02_A.mpg
Movie_02_B.mpg
The guides only go so far, what I need to know is which software will allow me to have all four files on the dvd, have a menu with links to Movie_01_A.mpg and Movie_02_A.mpg, but when the Movie_01_A.mpg link is selected, Movie_01_A.mpg plays as wells as Movie_01_B.mpg. The same for Movie_02_A.mpg.
I have copies of BsDVD (it came with the burner), and evaluation copies of Ulead DVD Workshop, Ulead Movie Factory 2, DVDit PE and Scenarist. I am trying to figure out which software I should buy.
Thanks in advance.--
Will -
https://www.videohelp.com/svcddvdr.htm start @ step 4
but most of those eval progs will do the business. Also try DVDLabSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
If I understand it right, your problem is the wrong linking inside your menu-authoring.
For using all 4 Films separately there should be 4 "buttons", each one linked to one movie.
Movie_01_A.mpg : Button 1
Movie_01_B.mpg : Button 2
Movie_02_A.mpg : Button 3
Movie_02_B.mpg : Button 4 -
(S)VCD2DVDMPG: Guides : Spruce DVDMaestro DVD Maestro
DVD Menu Studio
SVCD2DVDMPG
SVCD to DVD. SVCD movies on DVDR with menu.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I don't have DVD Maestro, can it not be accomplished with one of the 5 I do have?Originally Posted by ChrissyBoy--
Will
Newbie: Need help burning movies into DVD
By silveraden in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2010, 12:36 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
movies in WINAMP file want to convert to a playable DVD disk
By PBONNA in forum Authoring (DVD)Replies: 2Last Post: 3rd Feb 2009, 11:27 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 09:40
