Hello, I know this topic has been brought up before but it seems to fade away before it is properly answered. Many people, like me, are looking for a way to make audiocds that also include some video.
I don't want to have empty tracks when the CD is inserted in a CD player that the user would have to skip over. Therefore, according to past posts, the method would be done with the Philips Toolkit and Gear.
I have learned a little about toolkit. For my first project, I thought I would just make a single mpg VCD on toolkit. Here's what I did:
Made my avi compatible for toolkit using TMPGEnc and VCD Mux.
Then I made my project in toolkit and completed the build.
But, then I couldn't save it to CD using Gear Pro 6.03. I received an error saying that there was a problem with the bin file in line 1.
Anyhow, I would like to solve this problem, as well as many others. I believe this should be a much easier task...shouldn't it. I mean, this really isn't asking that much.
Yes, I am a newbie.
Yes, I searched, read, and tried first....but is the software that hard to use for this application or am I missing something.
Thank you much for your time!
I posted an answer to a similar question earlier...
https://www.videohelp.com/forum/viewtopic.php?t=156164
if this is what you are looking for, then I will try to provide more detailed information. -
Thanks for the note, but it reallt isn't that easy. Here are the requirements:
1. only audio tracks are visible by a cd player
2. can play audio or video in a dvd player that has vcd capability.
Shouldn't be that hard, but it seems that most ways of making a mix CD will show blank tracks on a CD player.
I appreciate the input but please do not reply unless you have made something that fulfills the requirements above or unless you have experience in the tools in the post above. Thanks!!!
"Toolkit" for using a laptop to play video and audio onto a tv
By bobogs in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2011, 21:49 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 06:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03
