I'm not too crazy about NeoDVD but when I need a quick compile, NeoDVD does the trick. Recently, I can no longer hear any sound when I use this program. Using other programs with the same video work fine. I've checked all the settings and they appear to be ok.
What can it be?
Thanks but I had already run the upgrade in January. It didn't seem to make any difference. I do think it has something to do with it being an XVID file but I do have all the correct codecs since all my other authoring programs have no problems with these.
Ripbot sound problem
By ratch3t in forum Blu-ray RippingReplies: 2Last Post: 20th Dec 2008, 08:26 -
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 18:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 03:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 06:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 20:22
