Ok. I created a vcd disk using US(NTSC) it said it created ok, however when I put it in two VCD Compatiable stand-alone players it could not read/play disk......... Any help would be appreciated.........
You have to put all the files into a "VIDEO_TS" folder then you burn that folder not just the files themselves.
Nop... VCD does not have VIDEO_TS folder.
I would simply use neoDVD to capture/encode and burn directly to VCD.
Or capture in MPEG-1 then use Nero to burn that mpeg file as VCD.
Haven't tried because I quit doing VCD a while ago. Doing only DVD from now on.ktnwin - PATIENCE
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 18:57 -
Joining a 3 part MKV
By yearofthespider2k3 in forum Newbie / General discussionsReplies: 8Last Post: 12th Jan 2011, 18:32 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
How old are you - part 2 (no lying now)
By yoda313 in forum PollsReplies: 95Last Post: 4th Oct 2009, 09:00 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36
