Hey guys 2 problems. First I have an mpg outta sync so how do I resync it ? and also How can I save a .mov from a stream source ? Can't right click and save as. Is there a program like asfrecorder or something ?
Results 1 to 10 of 10
Your first question is difficult to answer easily. Luckily, it has already been answered and all it should take is a little perusal of the forum to find what you seek. For your second question, there is an application called hypercam that might do what you want. The company that makes it can be found here - http://www.hyperionics.com/
I don't know about re-syncing an mpeg.
I do know that it is caused by a problem in the conversion process and that is usually the place to go about fixing it. If you still have the source file then explain your conversion process (as much detail as possible) and maybe someone can help.
"Art is making something out of nothing and selling it." - Frank Zappa -
Well see I dled an avi it was outta sync plus frames were skipping so i converted it to mpg hoping it would be better. The mpg plays ok not perfectly smooth but better but the sound is still outta sync so um yeah..
actually i am a cs student and after 2 semesters of cs fundamentals and assembly, it ain't a stretch.
so i guess my answer would be "no."
sure hope i don't end up doing it for a living. heard those guys end up pretty squirrely.
