From what I have read DVDSP is pretty
compatible with Final Cut. However,
I have Adobe Premiere and After Effects.
(also DVDSP 1.5)
I am trying to make animated menus,
well i am making animated menus
using after effects and premiere,
but can't figure out how to set them
up so that they can be imported into
DVDSP. I'm rendering the videos at
720x480–do I need to make them that
big? some of my menus are about a GB!
and they're only like 30 seconds long.
I gotta be doing something wrong.
Does anyone know if there is a Mpeg–2
exporter in either AE or Premiere?
If not (i dont think there is) is there some
other file type I could export as that would
be compatible with DVDSP?
email me @ fats414@hotmail.com and I will explain exactly how to do it.
If you're making items for motion menus, do not use mpeg files.
I've been told to use ANIMATION CODEC quicktime movies and make them 320x240 unless the final size displayed on the screen in pixels on the DVD menu is larger than that
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 21:06 -
Pin. Studio 14 ult.col. – problem with effects.
By harry34 in forum EditingReplies: 1Last Post: 11th Nov 2011, 01:29 -
FAST RENDERING of Final Cut Studio Pro and After Effects files.
By Kevin Whelan in forum MacReplies: 3Last Post: 24th Aug 2011, 12:40 -
Menu transitions/effects with Sony DVD Architect Studio
By sir_rob in forum Authoring (DVD)Replies: 9Last Post: 25th Jul 2008, 20:24 -
Vegas Movie Studio 8 Platinum Music/Sound effects
By Nuke Shower in forum AudioReplies: 3Last Post: 21st Apr 2008, 01:58
