I understand the principle of Action Safe Areas and the fact that due to TV overscan some of the picture on a televison will be lost.
The problem is that I am currently encoding and authoring AVI's created in 3D Studio Max (produced by others) into MPEG2 then burning to DVD. When encoded the images on the computer play back fine - complete image - however - on TV some of the image content is lost around the edges. According to my reading up on the subject this is due to overscan and Vegas video allows for a 10% loss of the action zone. When comparing the grid szone to actual image on TV it is quite close.
What I would like to know is to prevent this happening what size should the graphical content be to ensure that this does not happen - or are there any workarounds.
Also if anyone knows how to create a Graphic image (dimensions) for widesvcreen without it all being squished that would be useful too.
The TV standard is PAL.
Thank you in advance for any suggestions
TOMMO
3D Studio Max has Title/Action safe grid that you can turn on. Right click on the viewport name and select configure and there will be a tab for it...can't think of what it says exactly. You turn them on and you will see the grid in your viewport.
_ -
An easy equasion to figure this out is to subtract 10% from your max resolution and that is your Action safe area. Subtract 20% from your max resolution and that is your title safe area
Remove Blank areas from a video
By xstoanurag in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 20:37 -
Simulate green areas of bad compression
By elmuz in forum EditingReplies: 5Last Post: 24th Mar 2011, 06:28 -
Blocks in dark areas
By santosx in forum Video ConversionReplies: 22Last Post: 12th Oct 2010, 18:54 -
Is it safe to sell our free cell-phones? Also, is it safe to BUY?
By siratfus in forum Off topicReplies: 3Last Post: 12th Dec 2009, 15:30 -
Lower thirds and safe areas (Sony Vegas)
By sdsumike619 in forum EditingReplies: 2Last Post: 4th May 2008, 00:21
