Hello,
Using QuickTime 6.1.1 (PRO) I try to export to .mpg-4 a .mpg-1 movie that plays fine in QT with sound. The resulting .mpg4 file has no sound
any advice?
Bernie
MissingMpegEdit homepage.mac.com/rnc
Will overcome your mpeg 1 layer 2 audio problem. -
ok,
the .mpg i want to convert is a MPEG1 muxed
when i use mme it says: The variable theAudio is not defined. (-2753) and quits.....
file runs perfect in QT 6. when i use qt6 to convert to mpg4 i get video fine but 0 audio.
Bernie -
Well, right now QT Pro still has problems with muxed MPEG-1/2 files... here is my suggestion:
Use bbDEMUX to demultiplex the video and audio... the original file will remain.
Create a new, empty movie in QT Pro, then open the demuxed audio and video files.
Copy->Paste the video into the new movie, do the same with the audio, but I would select the whole length of the new movie and use 'Add scaled' in the edit menu. This gives more consistent results and helps ensure reliable splicing and sync.
Use the export option like normal, enjoying an .mp4 with sound.
I personally don't like converting heavily compressed formats like DivX or MPEG unless I absolutely need it in another format. (DivX fansubs to SVCD MPEG-2 for my DVD player for example) The quality drops, and there is very little you can do about it.Slaughtering the competition with amatuer-quality VCD authoring abilities... fear my non-l33t skillz. -
Ross,
ok i tried mme once again and found that i did not wait long enough for it to go through the motions ---- it uses bbdemux ....
so i was left with a demuxed mpg 1 file. then i converted that file in QT to my desired mp4
thanks!!!!!
Bernie
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
mpg has sound but no video
By Vachoen in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2007, 19:27 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 09:01 -
Sound for MPG is Gone
By pastorsam in forum Video ConversionReplies: 10Last Post: 24th Jun 2007, 18:34
