I've got a divx file(Life of Brian) which is 24.000fps. How do I encode it with TMPGenc to get the best quality?
25.000 or 23.976?
Regards Nille
Use VDUB to convert it to 23.976 fps. Then frameserve it to TMPG. You will have to look at the length of audio and video to see if you going to have sync issues. BeSweet can correct this for you with no noticable shift in sound frequency.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Vdub will work but its not necessary. Just set TMPGenc to 23.976fps output and on the advanced tab click "do no framerate convert." This will make TMPGenc physically slow the playback speed down, rather than just decimate frames.
24.000fps (not 23.976!) audio to 25fps
By Lastman369 in forum AudioReplies: 8Last Post: 13th Jan 2010, 09:58
