Ok here it is. Simple question.
Last night i used dvd2one on the movie Friday After Next.
When getting to the part about choosing the number of chapters.
There was two of them that had the same length but one had like lets say 15 chapters and the other around 30. (something like that)
So what was the difference in these two? I chose the one with the smaller number of chapters being they were both same length even to the second it confused me.
Movie did play just fine, just wonder what i am missing here?
the other odd part was that total size of files when done was only around 3.5gb shrinking it from around 7. thats odd cause any other time i used dvd2one it put it right at making a full disk.
ThanksWell better get back to work
It is probably that the disk had two versions of the movie on it. A Full Screen version and WideScreen version. The movie it self could probably fit on 1 disk without compression. Especially after removing unwanted subtiltes and audio tracks.
If you look at the VOB files that you ripped, do you see two sets of large VOB's? If so, then it is two versions of the movie. Also how big is each set? If each set is only around 4 or 5GB, then one version of the movie could fit on a DVD-R without compression. And the reason that it would be smaller than 4.7 after running through DVD2ONE would be because you removed extra audio which made it smaller.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
