I am trying to capture VHS tape in MPEG2 format and try to convert to VCD. Can any one tell me how to do the conversion after capturing so that Nero will not give error.
Results 1 to 14 of 14
ssv you should be capturing in MPEG1 VCD not MPEG2 SVCD if went to make VCD disk.
Got my site http://shs-tv.m0ss.com/. -
I read somewhere that if we capture in MPEG2 and then convert to VCD format the quality will be good.
SHS , I have another problem. when i capture in MPEG2 format the catured video is playing upside down. Can you tell me what is wrong? -
But you can capture to MPEG2 High bitrates and then convert to VCD with TMPGENC to get better quality. Read how to convert mpeg2 to mpeg vcd under CONVERT.
As Baldrick said you can do that but that going take lot more time then if where just record in to MPEG1 VCD.
As for quality diff must like be very little diff in quality.
You went take look at this page http://home1.inet.tele.dk/box5000/pvr.htm
As for "captured video is playing upside" sametime that cause by runing WinTV2000 and Windows Media Player at the sametime just make sure you install the latest DirectX, Hauppauge MPEG2 soft decoder & WMP 7.1 and should be fine after that.
As TecoLtd put it,
The different encoders did accomplish the tasks with different results, to be more precise one encoder was able to encode the trees in good quality but the fast movings caused problems, another one created excellent quality at
fast movements but crashed at the swimming pool - and so on. (Is not optimal choice... - again, I'm not sure what you mean here. You could say There is no optimum choice. A better way to say it might be, There is no perfect solution.)
ssv: http://www.vcdhelp.com/mpeg2tovcd.htm
it isnt so hard to find if YOU READ. -
Why not capture inMPEG2 so you can have a very good and sharp SVCD, I do MPEG2 to SVCD on my PVR with fantastic results, mine you you must have the reg edit patch to open up the advance control so you can manually change the bitrate, throttle, audio and res. settings. I set mine to the following
480x480 res.
MPEG2
2520 Constant Bitrate(leave the above setting at 5000)
Audio 192
Throttle at 0.070
Sharpness at 0.00
Now my sources are Hi8mm, DVD, laser Disc and Dishnet Sat., the SVCD's I make look great on my 36in. and even good on my dad's 46 big screen.
I can never get a VCD to look good at all from this card, I just usually record it as a uncompressed AVI from this card, then encode with TMPGE as a XVCD at 2520 bitrate.
You need to make sure your standalone DVD player can play SVCD and/or XVCD. -
Capture to VCD
letmeinforgodsake read my How to Use on my site
http://shs-tv.m0ss.com/ -
thxkid, can you tell me the step for recording XVCD using WinTV PVR and burn it on a CDR? What the hardware setting will be required? Thanks!
sorry for the late reply !
thxkid ,unfortunately my DVD player (Sony DVPS530D) doesn't support SVCD . But I never tried burning XVCD. I think the quality will of XVCD will be little better than VCD.what is that regedit patch?
letmeinforgodsake what Web Brower are you using I hope it IE
and you will need the flash player install in oder to see the menu's.
Capture with Hauppauge WinTV PVR.500 VHS
By Asesinato in forum Capturing and VCRReplies: 2Last Post: 31st Mar 2012, 11:33 -
Capture Lossless with WinTV-PVR-150
By rudolf016 in forum Capturing and VCRReplies: 50Last Post: 28th Feb 2012, 12:39 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 14:21 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 20:00 -
Video Capture with Wintv PVR 500
By radink in forum Capturing and VCRReplies: 3Last Post: 11th Aug 2007, 15:05
