Hi, I've created several SVCDs with menus and chapters. Friend's DVD player cannot play them. **I do not want to start all over from capturing avi, editing and then encoding.** I have two questions:
1. How can I convert the SVCD to VCD?
2. If I want to maintain the quality of SVCD, how can I add a header trick?
Thanks.
Software:
Adobe Premiere Pro - capture stills & motion, edit, render
Adobe Photoshop 7.0 - edit stills
TMPGenc Plus 2.5 - encoding, splitting mpeg
VCDEasy 1.1.5 - stills to mpeg, interactive menu, SVCD cue/bin
MOTV 2.10
Nero 5.5.8.2 - burn image -
I simply followed the guide for doing so at this site in the 'convert' section for converting svcd to vcd.
However the svcd header trick didn't work on my player... but I was trying to put svcd files to dvd in that case, which I don't believe you're trying to do. Thus all my svcd to vcd conversions do take a loss in quality but its, for me anyway, negligible. -
Thanks. I was trying to convert them from SVCD to VCD without having to re-encode. I've not found a solution yet...
Software:
MOTV 2.10
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 03:55 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 01:12 -
What is smpeg4 and is there a better way to convert then vcd?
By yoda313 in forum Video ConversionReplies: 12Last Post: 13th Mar 2009, 18:26 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
