I'm using Studio 8, running on WinXP.
I have problems capturing from my DV cam via firewire card.
The image seems to be staggering and not smooth, even tho it doesnt display any frame drop counts, but actually it is.
I dun have such problems when using Win98SE.
What's wrong?
Is the video file OK after the capture is done?
I know some capture apps only show a "rough" preview while capturing, like 15 fames per second.
If the files are skipping in exactly the same place every time you view the video, I'd say you do have some dropped frames.
Try watching them on a different PC.
Smooth accelerated video
By Bluelemmy in forum Newbie / General discussionsReplies: 24Last Post: 24th Feb 2014, 17:13 -
filter to smooth playback?
By kinglerch in forum EditingReplies: 14Last Post: 21st Oct 2011, 13:17 -
Would there be a way to smooth out audio dips in a vhs capture?
By yoda313 in forum AudioReplies: 27Last Post: 10th Jan 2011, 16:46 -
smooth slow motion
By nitrobaorder in forum EditingReplies: 22Last Post: 18th Oct 2010, 06:19 -
Video to smooth, what do you recommend.
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Mar 2008, 12:28
