  1. Ive downloaded loads of dvd ripped films off kazza, Direct connect etc and they are all in avi format..
    However I want to convert them into mpeg format so I can burn them to a normal cd-r (700mb) disk and watch them on my dvd player.
    Whats the best audio compressor software to enable me to do this as I don’t really want to put the films onto two cd-r’s
    Or is there any other way to get round this
    Cheers
    Please don't cross post. One topic is enough.
    Mar 2003
    Don't try to pu them on one cd, you will get VERY bad quality. Sacrifice 2 cd's intead, it's worth it.
    Dec 2002
    you can get 80 minutes of (low) quality VCD onto 1 disk. You can try xSVCD or xVCD and maybe get 2 hours of so-so quality. Since you are converting from 1 CD DivX/XviD, don't expect great results (your source is generally overcompressed).
    SVCD's (higher quality) are typically 45 minutes or so per CDR. Most good DVD rips are 2-4 CDR's.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  5. ok cool ill use 2 cd's. So how would i go about spliting them ???
  6. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You don't have to split them, you have to CONVERT them to compliant mpeg1's or mpeg2's. There's lots of guides one click away, right over there <-<-<- on the left hand column.
