whilst trying to view files that are being downloaded and then trying to view them on windows media player iget an error message saying error downloading codec and also file may be formatted by an unsupported codec . Anybody any ideas?
Download gspot from the tools section, scan your file and then install the relevant codec. Stay away from nimo, only install individuals.
Yep, use gspot or avicodec.
www.dvdrhelp.com/play#identify -
You need to install the codecs needed to play it. WMP won't download DivX or XviD or some ff the audio codecs. Go to the download section of this site and get GSPot to tell what the codec is. Then you will probably need the DivX 5.03 codec (contains spyware), the XviD codec, and MP3 audio codec, an AC3 audio codec, and maybe FFDShow for good measure(direct X play everything codec).
To Be, Or, Not To Be, That, Is The Gazorgan Plan
CODEC problem
By DavidPriest in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2011, 06:39 -
I think I have a codec problem. D:
By Neverwhere in forum Newbie / General discussionsReplies: 6Last Post: 24th Jan 2008, 16:02 -
Major 'Codec' Problem
By mattstan in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 15:18 -
MPEG4 codec problem
By kris3 in forum Newbie / General discussionsReplies: 3Last Post: 21st Aug 2007, 01:57 -
codec problem...
By cwb in forum EditingReplies: 6Last Post: 16th May 2007, 11:29
