Ive just finished a VCD ive been working on for a while, ive used VCD Easy and the VCD has got a lot of commands and stuff like that, heaps of files. I went to save it but i got the message 'Not Finished Yet Sorry' no matter what i did, it wouldnt save so i just closed it.
I thought i could make a 'disc image' like any other cd but it seems i cant do it. my CD-RW program is 'GEAR Pro CD-RW 6.0'.
is there a program that makes disc images of vcd and then burns them? i really dont want to go through all the VCD Easy commands again.
plllleeeasssee help, its quite important.
VCDEasy is just a front end to VCDImager.
Did you try to get VCDEasy to create a CUE/BIN image? What did you do exactly?
If you like full VCD authoring freedom, I suggest that you author the XML file yourself and then build it with either VCDXBUILD or lkVCDxBUILD...
http://www.michaeltam.com
http://www.vcdimager.org
http://www.michaeltam.com/vcdimager_tools_gui.html
Regards.Michael Tam
w: Morsels of Evidence
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 15:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29 -
VCD to DVD with subs - subpictures below video-image - Help?!
By nbarzgar in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jun 2007, 11:44
