I have captured a 90 minute concert from VHS using Dazzle's DVC 100 (which uses DVC200 drivers) and rendered an mpeg using Dazzle's MovieStar5 program. When I check the file, I notice that every now and then I get a strange 'blocking' of the picture. It looks like satellite TV does when it rains a little. Blocks trickle down the screen. This doesn't occur all the time but several times during the 90 minutes. I can live with it but am considering making DVDs for other people (home movies to DVD stuff) and don't think this is acceptable.
My question is: Is this a quirk in the capture/render part of the creation? And can the blocky frames be removed without causing me a nightmare of audio problems? I just want a clean picture start to finish.
All software used in the creation is up to date (including DirectX) and I have tried to capture using VirtualDub but it gave me errors.
Other info: Nothing else is running while the capture/render process happens to interfere with the programs or hog up RAM. And my system is quite capable of handling the task.
Thanks for replies.
Are the glitches in the source file/file you capture to (say an AVI). If so you are having some noise in the capture process, often due to a fault in the source media. You could clean it up using VirtualDub and mask the bad frames (this is a bit time consuming)
If the glitches are only in the rendered mpg file then it is an encoding issue, probably some type of bit rate shortage. I am not familiar with your programs but try altering your bit rate settings for the encode process. -
Your probably experiencing macroblocking, due to poor motion detection, or bitrate shortage. It seems like I remember the Dazzle hardware MPEG cards did a pretty decent job for quality, but it's still capturing directly to MPEG, with all that entails. You could try increasing your bitrate.
Impossible to see the future is. The Dark Side clouds everything... -
From what you've both said, it could be a combination of both motion detection and bitrate shortage. The glitches occur when there is a fast motion of the camera or a cut-away but it also happens in the middle of no motion but less frequently.
The capture/render program Dazzle provides with their device is limited in their settings. I'll see what I can tweak but don't think I can do anything short of running the mpeg in TMPGenc to correct the blocks...adding hours to the project.
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
audio glitches
By sandiegoguy in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2009, 14:24 -
Audio Playback glitches
By cmccarty82 in forum Authoring (DVD)Replies: 3Last Post: 13th Jul 2009, 13:07 -
Sync audio with glitches
By kimse in forum AudioReplies: 0Last Post: 22nd Jul 2008, 07:50 -
Trouble makeing a DVD without Glitches
By mongoo13 in forum Authoring (DVD)Replies: 3Last Post: 27th Apr 2008, 03:51
